Help Please...im Stuck
Thirty38eight
Thirty38eighT
okay...i tried installin a pioneer HU in my 2000 sentra...connnected all the wires, checked to see if it worked b4 screwin it in, it worked but after i screwed it in it didnt work...checkwed the audio fuse under the hood...i blew it. i replaced it but still nothing...checked the fuse in my amp...fine...the fuse in the HU is fine...i replaced it anyway...put it back in...still nothing...thinking I blew the HU, i hooked the constant power line and the switched power line to the + battery terminal, and the ground to the -, it worked fine...i bought a new metra wire harness, hooked it up to the pioneer harness, and still i have no power to my reciever...this is not the only forum i have asked and still i have no answer... o and if this helps now the interior lights to the thermostat do not work unless i put the rear defroster on...this just started since i put the new HU in...i also tried putting the sony i used to have back in...same problem...please help i have been struggling for 3 days now
Problem sounds like it's between your fuse box and your wiring harness. Maybe there's more than one blown fuse you're looking for? Check under the dash for a fuse box as well.
yea i just woke up and i found the fuse box under the dash but it doesnt say anywhere which fuse is which i really dont feel like pulling em all out to see if one is blown or not
someone in a diff forum told me that the antenna may connect somewhere futher down and that could be diconnected, but i tugged on the antenna, and that bi*ch was 100% connected so thats not the problem
Sounds like you got a short in the head unit harness somewhere that is grounding out when you put everything back in the dash . I would check the wires over carefully //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thirty38eight
Thirty38eighT
Thirty38eight
NEW YORK
Thirty38eight
michigan born
    May 14, 2026
michigan born
    May 14, 2026
