chsvick5
Guys well ive been running this amp for bout 6 months i had sold it to a friend of mine which btw he is a *******. He had it hooked up to around .5 ohms on a stock electrical at full blast. It would run for bout 5 10 min then shut off. I took it away from him and im running it at 1 ohm. I have 4 opti 1232d on it running at 1 ohm. The problem is it doesnt sound the same. Suddenly one day i heard it less. So i checked everything and it was wired good. The battery fuse was not tight so i replaced it but still is the same. I connect 2 subs and it sounds good. I connect the other two alone and the same. Then i connect all 4 and it sounds the same not louder nor anything. I replaced my rca's and nothing. What can it be please help!!!
P.s. I just ordered another amp which should arrive wednesday.
