Help on my mojo15@kx1200.1
timm
10
CA
pls help
i went to this shop a honda hatchback has 2 10 inch lanzar subs on a ported box and a rockford 501s and his set up is almost as loud as mine
pls help whats wrong with this set-up
hu:pioneer 4800
subs:memphis mojo 15inch @1ohm on a ported 3.25cu ft 35hz vent tuning
amp for sub:kicker kx1200.1 using only 4ga power wire and a anl fuse holder with 150amperes
3-way x-over:kicker kx3
seps:jl xr650
rear speaker:stock
im using a medium size medium power battery
problem2=sumtyms my bass is so powerful after 2 songs my bass lessens pls help
thnx in advance
by the way car is nissan cefiro2000
ty
this is my HU AMP CROSSOVER SETTINGS
amp bass boost is at 1/4
amp gain is about 1/8
amp freq 50
x-over sub out gain is 3/4
x-over freq 70
x-over sub out bass boost 1/4
HU volume is 30 but maximum is 60
HU EQ settings are VOCAL
HU SLA is +1
your setup is very respectable. only thing i can suggest is maybe a ho alt, and soundeading. tuning higher will get you louder but cost you on the low notes.
this is my HU AMP CROSSOVER SETTINGSamp bass boost is at 1/4
amp freq 50
x-over freq 70
HU SLA is +1
Turn your gain up from 1/8 to a little less than 1/2. that will help a lot.
Also are using the remote bass knob? If so you need to turn off the bass boost on amp to zero. Using the bass knob now only controls the gain in order for you to get the full range of gain the knob will be all the way to the right. Ultimately you may need more power but at 1/8 gain you won't be getting it. Keep us posted...Polo.
PS- I had these 10's on almost double there rms >
a bigger box will help out since you dont have alot of power, is that a dual 2 or quad 1 mojo? reason I ask (and I could be wrong, so correct me if i am) is that the quad mojo has more spiders, and that ultimately leads to a stiffer suspension, which kinda means its not all that efficient...
my buddy has two RF HE2 12's sealed and a 501s and it was quite quite loud... dont underestimate, and hatch = loud... what is a cefiro2000?
timm
timm
CA
CRXBMPN
