DjDecibel
Hello!
i just bought a bmw e36 Coupe, and this is the problem.. it has a sealed trunk!!! the only holes between the trunk and the car interior are the original 4" speakers holes!
The list:
Vehicle : BMW 325i e36 Coupe
Location in the vehicle: Trunk
Space available (Length x Width x Height):
Subwoofer make and model: Spl Dynamics Pro 12D2
Subwoofer Size: 12"
Number of Subwoofers: 2
Type of Port (Kerfed, Slot, Aero, etc.):
What type of music do you like?: Techno / Hip Hop / HardStyle
Is your goal SPL or Everyday Music?: EveryDay Music
Tuning Freq (Hz):
Volume :
i already own:
2 X Spl Dynamics PRO-12D2 MK-3
Power handling (RMS/Peak): 500/1000 W
Nominal impedance: 2 x 2 Ohm
Mounting depth: 6.62 inch
Mounting diameter: 10.87 inch
Magnet diameter: 6.7 inch
Magnet height: 1.58 inch
Magnet weight: 130 oz
Voice Coil diameter: 2,56 inch
Voice Coil Type/Material: DVC/BASV
Fs: 29 Hz
Vas: 1.907 ft^3
Qts: 0,42
Qes: 0,44
Qms: 6,1924
Xmax (lin/peak): 0.67/1.34 inch
Re: 2 x 1,8 Ohm
Mms: 217 g
BL: 18,1 TM
SPL (1W/m): 86,8 dB
Box suggestions:
Closed box 0,918 - 1,413 ft^3
Bass-Reflex box 1,130 - 2,119 ft^3
here's my idea: a reflex sloped box with thos 2 subs and the vents on the seats side, so i will open the rear seats when volume is up
like this
can anyone help me with my project?
how many liters should it be?
The list:
Subwoofer Size: 12"
Tuning Freq (Hz):
Volume :
i already own:
Fs: 29 Hz
Vas: 1.907 ft^3
Qts: 0,42
Qes: 0,44
Qms: 6,1924
Re: 2 x 1,8 Ohm
Mms: 217 g
BL: 18,1 TM
SPL (1W/m): 86,8 dB
Box suggestions:
like this
