Help on deciding which sub or sub combo to get?
EdSteezy25
Hi everyone! First post here lol
Ok so I need help on deciding what sub combo to get.
I'm already dead set on getting JL Audio W3 and my amp is the Alpine MRX-M55 and the birthsheet puts my amp at 592 watts rms @ 2 ohms.
So I recently went to my local JL dealer and asked what would yield more output a single 13.5 inch W3 (which has a 600 watt max rms) or two 12" W3s on 296 watts each (300 watts is supposedly their "optimum" rms).
So what it comes down to I guess is one fully powered slightly larger sub vs 2 mildly powered 12s.
The owner said the 2 12s would be louder.
PS they'll be going into a ported box.
In this case cone area wins. Don't base your power off a birth sheet, they are very misleading. They are tested on a bench and resistor, two things you don't have.
Why are you set on that sub? What did you compare it to?
I figured these subs are a nice balance between SPL and SQ without needing too much power. And I want some SQ after coming from a 1100 watt powered 12 XFL. But I then sold my MRX-M110 and got a M55 but I doesn't push the sub at all lol
The amount of output I get from the XFL on the M55 actually saddens me. It really doesn't compare to when it was on the M110.
I figured since the W3s have a higher sensativity and smaller motor they could get louder on the same amount of power
I actually have never checked but I'd assume so since it absolutely slammed on the M110 and all I did was swap out the amp. I had it installed at a shop when they made the box for the sub.
EdSteezy25
EdSteezy25
Eugene, OR
LosIsATool
