help on bridging 2 amp's together
i think those are lightning audio amps? what is the RMS wattege and at what ohm load on the amps? also what are the subs and voice coil configurations? might be just as easy to hook each sub to each amp.
you guys are prolly confusing the fck outta him with all the ohms and voice coils talk //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif try to explain easier to him. if he doesnt know the difference between strapping and bridging, or even how to bridge an amp, i would try to get him an easier way to explain.
That's why I want the actual model #'s //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif So I know what we are working with, what will work and what won't work, in order to explain to him what will/won't work and why.
i just want to bridge 2 amps together and hook one sub to each amp. i hook up a duel amp wire kit and the main wire that runs from the battery runs to the back of the car then runs into a splitter that has two wires which are for 2 amps which gives it power and i run the ground, REM, and 12v so one amp has everything but the other amp only has power (12v) and i was talking to a friend and he told me to have someone hook it up but i did it myself and he said to bridge the amps together and i dont kno how to
wanna-be
wanna-be
Delaware, Ohio
wanna-be
