HELP!!! new amp cuts off!!
phoenix gold xenon 1200.1
two phoenix gold RSDC 12" subs [600/1200]
so my amp is rated @ 1200rms, my subs together are 1200.. wtf?
i have my gain all the way up and bass knob turned up a little bit. dont really know whatto do with sub sonic or the other knobs.
i have a dmm and would like to set it properly but dont know how.
1) the gain knob isnt a volume knob. Learn how to use it
2)use the search feature, you will look less like a n00b. "gain setting tutorial"
3)if you dont know what filter knobs are, you need a new hobby //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
do some searching.
to spell it out for you. that is his problem. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
maybe i guess i should have said my headunit is a kenwood excelon x493
so amp gain to 4v. i just thought it would need to go higher since my subs can handle what my amp pushes.
and ot answer the question my amp isnt bridged. well its bridged internally in paralell. i wired my subs in series-paralell to 4ohm load each and ran to its own seperate input on the amp.
i know it sounds weird but thats how the xenon amps are.
and theres no reason for you guys to be this negative. I came on here knowing I needed to use a dmm and a 50hz sine wave to test my rms output. I just need help understanding what voltage Ill need.
kingkongtrunk
kingkongtrunk
chicago,il
kingkongtrunk
