Help Needed
LGhost
7
Chi
OKay... Hooking up subs and amp in truck
Power on amp fine. I believe the problem is the rca outputs on the radio...
I have a car that I tested the amp and speakers in and was fine.
The only difference is the head units. The head unit in the truck was used previously with a different amp and worked fine.
Okay so, the amp is "Alpine - 4/3/2 Channel Plus Subwoofer Drive Power Amp"
The rca inputs are as follow - White on top, red on bottom...
Left Top & Bottom = Channel 5 Subwoofer
Middle Top = Channel 3
Middle Bottom = Channel 4
Right Top = Channel 1
Right Bottom = Channel 2
The head unit in my car has a subwoofer output too and is what I used to use channel 5 and worked.
The head unit in the truck only has 1 rca output.
You have to actually put your ear on the sub to tell its getting a little power( in the truck )...
its not the radio because i took a rca output and hooked it to the ipod in both the car and truck and it worked in the car but only had very low sound in the truck...
LGhost
LGhost
Chi
Einzee
