Help Need, Rainbow and ID
psychonaut
hey
i have a 4 channel kraftwerk rainbow amplifier with me, a set of Image Dynamics CSX 6 chameleon components(2 ohms) and an image dynamics IDQ subwoofer(4 ohms)
how much power can the amplifier give to the components and the subwoofer respectively?
Heres a link to the specs:
1. Amplifier
http://195.243.203.21/rainbow/techni...111121&lan=eng
2. Components
http://www.imagedynamicsusa.com/prod...&Product_Id=29
3. Subwoofer
http://www.imagedynamicsusa.com/prod...&Product_Id=18
if i get my subwoofer replaced from 4 ohm to 2 ohm, will it make a significant difference??
If so, that amp will send about 130rms to each side of the comps @ 2ohm (running passive crossovers). With the d4 idq you could send it 130rms @ 2 ohm. If you got the d2 ohm version you could send 260rms @ 4 ohm to the sub.
so, if at all i get a d2 version sub, is there going to be any improvement as such?
Also, how much power is my amp going to give at 2 ohms, NOT 4 to the components and the subwoofer if that is the case?
Thanks
psychonaut
psychonaut
India
psychonaut
