help me
  • Thread starter wiltonmedina
  • Start date
  • Replies 3
  • Views 482
  • 1
the noise that i talk about is like a high pitch siren coming out from the speakers, specialy from the mids, that noise just can be heard when the volume of music is low or with no volume at all.
i hope that you can help me in solving that soon or i am going to get crazy about it.
thank you buddy
did it make the sounds before the stereo stuff was put in? if it did, it could be the blower motor going bad. if it didn't , well, a couple of things. first, the grounds. make sure everything is grounded correctly. second make sure you don't have the speakers chassis grounded(grounded to the car), which leads to this, go back over ALL the wiring aand make sure it's correct. you could have a bare spot in a wire that's trying to ground out.
116
433
406
Guest
mrray13
    May 31, 2024
    May 24, 2024
