Jroo
This is what I know about isobarics in ported boxes. The port lengths and tuning dont change, but the enclosure size can get down or cut in half when you add the second driver for isobaric. In theory if I have a design for a ported box and add the Iso, the port lenght and tuning dont change, just the box size.
Using my thought, I found a box design for a DD 1508. The guy called it a 4th order T-Line. Basically its a DD 1508 in a sealed section dead in the center with a long port that wraps around the sealed section(he called this the T-Line) and ports out. Lets assume all the math is correct for the T-Line section. If I want to make this design isobaric and add a second driver. I would not change the line length or line size? I would just cut down the size of the center sealed section and add the second isobaric 1508? So lets just say the sealed section is 1 cube, I would make it 0.5 cube, add the second driver and keep everything else about the line the same? Does this sound right so far?
