Help me with system issues
ThatChevyGuy
sue me, its a ford.
Im getting no output. My cd player seems to working normally, and my amp is green, and nothing is burnt. Cd player is a 4 year old pioneer though, so i figure the rcas went. I dont have any friends that have systems, so how would i go about testing outputs on my deck and the output on my amp? I dont have any other cd players or amps.
meh, ill try to find one, im not buying one for sure though.
Yeah I wouldn't want to own one as it's not like you'd ever use it again for any car audio issues. They're over rated and a total waste of $20 //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Mine was a lifesaver. Remote wire broke under the insulation. I triple checked all my connections, amp had power on the 12+ and the negative. I got the voltage at the unit, output was 12. I measured the voltage at the end of the remote in my trunk, zero. New run of wire, amps turned on right away.
DMM=great ivestment.
Do you have a boom box with RCA outputs, or a home CD player? Just drag either one out to see if you get sound out of the amps. Be careful if you use a home CD player that does not have a volume control because you will have a full bore (cranked) signal coming from the RCA outputs.
Hope you solve it.
ThatChevyGuy
sue me, its a ford.
ThatChevyGuy
Georgia
frzninvt
