Help me with shopping list pretty please....
Cajundude
I am in the middle of sound deadening right and am slowly putting a system together. Right now I have all of the interior ripped out of the car. Should I go ahead purchase all the cables now and run them since the interior is out of the car so I won't have to pull it again? I won't do the system for a couple of months.
More specifically, if I do go this route, can someone give me a list of wires I would need? Here is the tentative system for now:
Head unit - undecided
Components - Either Focal 165k2P or Boston Z6
Subs - (2) JL 10w6v2
Amp for subs - JL 1000.1
Amp for components - JL 450.4 (Is this a good choice for the components?) - Will I use channels 3 and 4 if I'm only running the front components?
The crossovers for the components will be located in the rear and the subs and both amps will be in the rear of the vehicle so, I would need...
0 AWG from battery to back
Suggestions on ground wire? Short as possible right?
RCA cables to go from amp area to HU area - 1 per amp
4 AWG wire from distribution block to amps
Speaker wire from amp area to each door
Remote turn on wire from HU area to amp area (1 for both amps? What gauge?)
Thanks for the help!
you are gonna spend alot of money on that system....
Try to keep the ground wire as short as possible but if you need 4 ft or so it wont make a difference. Gonna need 2 grounds or 1 single ground distro'ed to 2 grounds.
you pretty much got everything else figured out
Yeah, that system will sound nice. The only thing I'm wondering about, is why you're getting a 4 channel if you're only using 2. If you're not going to have rear deck speakers, or not going to amp them, then get a 2 channel amp. Good luck with your system.
Cajundude
Cajundude
Kemah, Texas
Cajundude
