Help me with improving my Jeep stereo please
If I run the the 4 channels of the amp for the front 4 speakers, how many sets of rca cables do I need to the amp? I'm leaning towards this amp instead of the one you suggested. I want the smaller footprint of the amp, and I don't think I need the extra potential power. Powerbass seems to get good reviews on the forums from what I read. PowerBass ASA 700.5X (ASA700.5X) 5-Channel AmplifierThanks for all the help so far. Just want to make sure I order everything I need right away so I can just hook **** up.
3 pairs RCAs. If you need to get some decent ones for cheap, check monoprice.com. You can go with powerbass 5 channel too its a workable choice also if you want to keep the budget low, it shouldnt take much power to drive your setup.
So get a 4 gauge amp kit, and buy 2 more pairs of rcas off monoprice and you should be fine. If you want to spend more, you can get knuconceptz, sky high or something fancy but difference is very minimal if any unless you car's environment is a very electromagnetically noisy. Just be sure to wire the power wire on the opposite side of the RCAs.
Thanks. Gonna finally order this stuff here tonight or tm. I appreciate the help. I'll probably not have it all installed for a couple weeks, but I'll update when it's all done.
PA85
PA85
MN
PA85
