Help me understand please
to better answer the OP's question, what happens when you bridge the outputs of a 2 channel amp is that each channel only effectively sees 1/2 of the total impedance you place across the bridged amp pair. So if you bridge an amp and place a 2 ohm sub on it, each channel will think it's playing into a 1 ohm load ...... some amps can handle that (even if they are only rated at 2 ohms per channel) and some can't. As stated above, it will become immediately obvious if you're amp can't - because the protection circuit will cut in.
As for the monoblock comment, what he was getting at is - most class D monoblocks are designed to drive 1 ohm loads.
wrong....some class d's are not 1ohm stable
jrdbrn
jrdbrn
Larose, La
PaulD
