IA 20.1 Issues
lvfive.o
I finally tried out the IA 20.1 I bought off of a forum member here like a year ago and I think I got a bad one but I am not sure.
The blue light turns on just fine when it powers on but I am not getting anything out of my sub. I made sure the posistive was on the positive the negative on the negative. After about a min or so I smelt voice coil and felt the sub and it was hot already but it hadn't made a noise. Any ideas?
is your sub cone locked up?, generally if something crapped out on the amp, it would trip into protect. I have seen the inputs on amps go bad and in that case, nothing would happen, just as described.
K, I am not sure I just pulled out the 35.1 to put back in the boat and the sub was working just fine right before I pulled it out, I put this one in and it is not working.
Well I just put a DMM on the outputs of the amp while it was playing, it only varies from .020 - .040 Volts AC, while my 4 channels varies from .005 to .800 Volts AC while playing.
lvfive.o
lvfive.o
Las Vegas
pawn man
