Hey, sorry I'm a newb but I got a few things I need to understand.
First. Do you need two RCAs from the deck to the amp? One set for each set of channels A/B, C/D?
Second.Can a 4 channel amp run 2 different Ohmages(a word?). Like 2ohms bridged on the A/B and then run 4ohms on the C/D?? or does it have to be the same?
Third. Just for kicks, when you're installing sound deadining in the doors, where do you guys put it. I know everyone puts it on the metal that the speaker gets screwed into, but do you put it on the metal surface behind that sheet. Like what would be the actual door not the panel?
Thanks
Thanks
