Help me set my systems crossovers
Aaron0731
I have what I feel is a nice JVC kw-V820bt head unit with a ton of settings. I'm running JBL gx 600c front 6.5" components and the stock Boston Acoustics rear 6x9s in my 2010 Camaro. These are powered by a 4 channel Sound Ordnance M75 amplifier. (Crutchfield in house brand, pretty impressed!) it's putting out 75W rms x 4 at 2 ohm. For bass I'm running 2 12" Kicker Comp C in a sealed enclosure powered by a Kicker 600W mono amplifier.
Since I have every setting I need at my fingertips I want to use the deck settings rather then the amplifiers for crossovers, slope, etc. Would someone give me some good settings to start with please?
u can start anywhere, 1st set mids and tweets turn subs off play something with bass, set fronts to like 100hz see if they distort if they sound real good lower it if u hear distortion go up to next freq (this is with speakers faded to front) try 24db slope,, set tweets at like 5-6k 24db unless someone here knows those speakers u just gotta listen.. then fade to rear do same.. sub basically set lp right at where ever u set hp on speakers so it'll play whatever they don't, so if u set doors at 120 rears at 100 set sub at 100-120 hz 24db then play all together see if sounds good and u can try different slope and freqs once u have that base setting
Aaron0731
Aaron0731
Indiana
BOOMINGRANDPA
