help me set my amp please....
chillout25
I just recieved all of my setup in the mail and I want you guys to help me set m amp or at least tell me how everything should be untill i bring it to the shop
anyways this is what I have my sub specs are these:
Sensitivity: 92.8 dB
Frequency Response: 26-1000 Hz
Recommended RMS Power: 550W
Peak Power Handling: 1100W
they are two audiobahn 12s wired at 2ohms to the amp
they are in a sealed box with 1.00 cubic feet per chamber
on my amp i can adjust
phase shift : 180 or 0 degrees
subsonic : 14-40
low pass: 50-150
bass boost : 0-18db
I have a Panasonic MXE CQ-C7401U with 5 volt preouts
thanks for your help in advance
Phase shift = 0
Subsonic = depends on box tunning. For now set it @ 25hz
Low pass = depends on system. Start at 70hz and adjust it up or down to blend with the rest of your system.
Bass boost = 0 never use this.
Set your gain with a DMM. Read the sticky in the amp section of this forum.
What amp/box do you have?
chillout25
chillout25
nb, ct
chillout25
