help me select an amp for front stage...
  • 2
xmywarx
What amp should I use to power my two sets of speaks up front?
I got rockford FNX series 6 1/2 components in the front doors and
rockford HPC 6 1/2's in the back doors.
I havnt replaced the dash 4's yet but Im not gonna amp those anyways.
So what amp do you guys suggest for the two sets of 61/2's? also what 4's would you guys recomend for the dash?
thanks,
mick
look into the theory of superposition and decide if that many source points (speakers) is something you really want to do. personally i wouldnt use the fours as they will be fighting the rest of your speakers. your imaging will go right out the window for the sake of volume which a 4 inch that isnt crossed over in the component system up front will also not work propperly with it. i would suggest a rockford 600.4 or a 400.4 considering you already like rockford.. if not jl and memphis along with about 10 others produce a worth while amp.
488
537
564
xmywarx
xmywarx
VA BEach, VA
audiolife
