Help Me Please!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 5
NMBR1SPT
I Might Be Your Dad.....
TO whom that can help, I need a video survlnce system for my house, I need like 4 cams and some kinda dvr or a way to record without using vhs tapes, help me plez. don't want to spend more than $500 if possible, thanks:D
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
NMBR1SPT
NMBR1SPT
Orlando, Fla.
Scoobydoo
