Help me picking my subwoofer <3
Slaugh
CarAudio.com Moron
hey im looking for my sub and i want you guys to tell me which one should i pick...
i want a smooth and clean bass... i want something more SQ, but of course it has got to have a little SPL too so when i want to hear music louder i can //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i made a list with the ones i can afford, and i want you guys to opinate about these subs and tell me which one is the best for me... tell me your experiences with them too if you have any...
ill probably run them on a vented box btw... i preffer over sealed....
if you know any other around the same price of these, please tell me i could probably search about it too //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
-Fosgate 12" P-212 S4
Size 12 inch
Type Woofer
Voice coil Configuration - Single
Material - Aluminum
Description -
2"
Cone Material Poly/Plastic -
Parabolic Injection Molded Polypropylene
Frame Material Frame - Stamped
Material - Steel
Surround Material
Spider
Crossover
Specifications Power handling(RMS) - 200 Watts
Power handling(Peak) - 400 Watts
Impedance - 4 Ohms
Sensitivity - 86 db
Vas - 97
Fs - 25
Qts - .488
Xmax - 11.0
Dimensions Depth Bottom mount - 6.1 in.
Cutout - 11.13 in.
Displacement - 84.67 cu in.
Magnet weight - 60 oz.
Enclosure Sealed box -
Recommended Volume (Cubic Feet) - .85
Ported box -
Recommended Volume (Cubic feet) - 1.25
F3(Hz) - 32
-Pioneer 12" 306C
Frequency response: 18 - 2,000 Hz Sensitivity (1W/1m): 89 dB Maximum Power: 1000 Watt Nominal Input Power: 400W QTS: 0.331 Lowest resonance frequency (FS): 33 Hz Vas (litres): 54.39 Recommended Sealed Enclosure (litres): 42.
-Pioneer TS-W125DVC
Interlaced Aramid Fiber Reinforced IMPP Cone Woofer 3-Layer Fiber Woven Radial 4-Layer, Long Voice Coil 12-Slit Aluminum Voice Coil Bobbin Double Mass High-Power Magnet Conex Damper with Damper Ring Projected Pole Yoke with Vented Pole Molded Gasket Accessory Grille (UD-G305) Available 800 Watts Max. Music Power 400 Watts Nominal Power Handling Sensitivity: 89dB (1W/1m) Frequency Response: 18 - 2kHz Recommended Enclosure: 1.5 Cubic Feet Dual-Voice Coil Design (2ohm or 8ohmn) 2ohm Rated (Parallel Wired) 8ohm Rated (Series Wired)
-Bravox UXP 12D 2
Impedância 2,0 + 2,0 (ohms ± 10%)
Sensibilidade 88 (± 2dB/m/2,83v)
Freqüência Ressonância 32 (Hz ± 15 %)
Gama de Resposta 25 - 1000 (Hz)
Potência Máxima 800 Wmax
Potência Nominal 400 Wrms
Qts 0,47
Qms 5,29
Qes 0,51
Vas 61 litros
XMáx 8,0 mm
Re 1,8 + 1,8 Ohms
Sd 0,0530 m²
12" D 321,0 mm
H 168 mm
it's an Alpine MRV-1000/400watts rms@4ohms bridge and 600watts rms@4ohms bridge
im just a poor brazilian, i cant afford more than that... im ghetto //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
WTF
that last one looked hella cool lol
im sure you could talk to Mike at SoundSplinter and he would ship you an rl-p, he seems pretty **** cool, of course it would be alot for shipping, im guessing about 300shipped or so to brazil
guys it's nearly impossible to ship subwoofers (or anything) from US to Brazil...
i remember UPS wanting to charge me nearly 300 american dollars ONLY for shipping a CDA-9815 head unit... and i would still have to pay 60% of the product price for custom dutys //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif+++ on a head unit i was ebaying for 222 dollars
what i have i bought used (VERY used //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif)... that's why my HU and Amplifiers aren't that bad...
i need something according to my reality
thanks //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
No way! US Postal service all the way
Sure, you might have to wait 10 weeks for a surface shipment. But an RL-p12 to Brazil would run $75 for shipping--roughly three times what it would cost on average to ship one within the US. One week airmail is $140. It is no doubt more expensive than domestic shipments, but you also have to figure that the dealers over there are charging much more for products that sell here for less. Thus, a trade off.
FedEx is also nice for US-to-Canada shipments since it costs about the same as USPS Surface and takes roughly 1/10th the time... (though FedEx does require a lot of paperwork for their International Ground service which drives me up the wall)
Granted, the aforementioned options are likely to be over our Brazilian friend's budget - but there are quite a few people that do buy products over lengthy distance and have no problem paying the extra for shipping; since in all honesty (and not to toot my own horn!
), there are a nice variety of US-based woofer solutions that either aren't available internationally, or are available at incredible markup.
Everything is relative though - there is great bass everywhere .. different types to be sure, but bass nonetheless!
Good luck on your system Slaugh
rly?? have you ever heard it??? is it good? what other sub does it compare to??
thanks
i would be going off a car sound review but the other 3 woofers i have messed with.. you guys still get soat in brazil? when i was a distributor here we did alot of soat
Slaugh
CarAudio.com Moron
Slaugh
São Paulo, Brazil
audiolife
