Help me narrow down top 5 choices for SQL single sub setup
300ZX Twin Turbo
PA
RD alpha
Jl w7
Treo Ssi or SSX
JBL GTI
Diamond D9
Running off of saz1500d
Either 12" or 15" single sub setup depending on space requirements
Probably ported looking for something with great output and great sq on lows and highs thts musical transitions well and jus sounds flat out sexy lol....
Been doing some reseach on these and can't decide...
You're looking for something that can play complex musical passages? For good transient response, you want something with low inductance (the Le spec), unfortunately most companies don't offer this up.
However, if you search over on DIYMA both the 10 and 15 GTIs have been Klippel tested, and both have an inductance lower than most 7" drivers, which is pretty outstanding IMO.
JBL hands down, out of what you're considering.
LOL well know i dont play complex musical passages mainly rap but the dd's jus seem sloppy and slow to me between diff ranges... I jus want tosmething that sounds good and gets loud since ill only have one 12"
Ok ok sounds good will i be dissapointed in the output coming from 2 dd's 2512... or do you think maybe i should go with some 10" im trying to steer away from 10" due to lack of low end IMO is tht true??
Maybe thts what I'm tlking about the WGTI... I thought the bigger the cone the bettwer low end reproduction bcuz if thts the case I might go 3 or 4 10"
300ZX Twin Turbo
300ZX Twin Turbo
PA
300ZX Twin Turbo
