Bassphreak
Ground Poundin' bass
Hi,I'm new to the forum but am having some trouble with which of these two subs is going to deliver the bass I want and take a beating.
Well I will be buying two new 12" subwoofers this weekend and I was planning on going with Audiopipes Eyecandy 12" TXX-AP12BL 4 ohm DVC subwoofers,but I am also thinking about getting two Alpine Type R SWR-1242D 4 ohm DVC subwoofers.
I like ground pounding bass,the kind that is heard and felt outside the car and not that I would want to do it intentionally but have the ability to set an alarm or two off.
I am thinking of getting the Two 12" Audiopipe Eyecandy TXX-AP12BL subwoofers placing in a 4 cubic foot or 6 cubic foot box tuned to 35Hz or 45Hz.They would be wired to present a 1 ohm load to a Lanzar OPTI2000D monoblock amplifer for 1600+w RMS (800+w a piece).
I have provided all the specs I could possibly find on both subwoofers (Type R and Eyecandy TXX-AP12BL) below,but I need your help to get the one that are going to pound the loudest,deepest possible bass and give me that ground pounding bass that rattles things outside the car.
Audiopipe Eyecandy TXX-AP12BL Specs:
Max Power = 1600w Peak
Continuous Power = 800w RMS
Frequency Response = 23Hz-1000Hz
Sensitivity = 96 db's
Surround = Air Cushion Foam Surround
One Piece Aluminum Cone
2.5" 4 layer black aluminum 4 ohm DVC
Nomex Spider
120oz magnet
Candy Blue Diecast Metal Basket
Fs = 30Hz
QMS = 6.55
QES = 0.48
QTS = 0.44
Vas = 1.84 cubic feet
Vas = 51.5 liters
Xmax = 0.55 inches
Xmax = 14 millimeters
Max vented box recommended = 3.0 cubic feet
Round Port Size = 3" x 8"
Minimum vented box recommended = 1.8 cubic feet
Round Port Size = 3" x 6"
Alpine Type R SWR-1242D Specs:
Max Power = 1500w Peak
Continuous Power = 500w RMS
Kevlar reinforced pulp cone
Surround = Santoprene Rubber
Ported Box Volume = 0.75-2.0 cubic feet
Port Size = 3" x 9.9"
2" 4 ohm DVC
Nomex Spider
Aluminum Diecast frame
Sensitivity = 85 db's
Frequency Response = 25Hz-500Hz
Fs = 29Hz
Vas = 45 liters
Qts = 0.47
Xmax = 18.2 millimeters
Xmax = 0.71 inches
Nomex Spider
120oz magnet
Fs = 30Hz
QMS = 6.55
QES = 0.48
QTS = 0.44
Vas = 51.5 liters
Xmax = 0.55 inches
2" 4 ohm DVC
Nomex Spider
Fs = 29Hz
Vas = 45 liters
Qts = 0.47
Xmax = 0.71 inches
