help me identify sub specs...... please!!
d2k
hi all......//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i need to find out the specs & manufacturer of this sub..?? its 750w peak with a 4ohm DVC, the code on the basket is ''PU-750''
that's it, i have no clue what RMS wattage is... or the company that produced it, i know ''Rockford Fosgate'' do Punch components but its not stated anywhere but the dustcap...
so... name that sub!! //content.invisioncic.com/y282845/emoticons/santa.gif.e1ec9cf2e0a0dd232ad35aa594a126d0.gif
you lot in the states have GREAT subs!!! ..... there is one place i found over here which has the same sort of knowledge im seeing here ''Talk Audio'', but there's no custom subs here (which is what i would like), there's loads of great deals in the FS section but subs are heavy & postage will mean re-mortgaging my house..lol //content.invisioncic.com/y282845/emoticons/graduate.gif.d982460be9f153bb54e5d4cb744f6ae8.gif
Hmmm..Well, to finger someone, you have to get them very turned on because when this happens, their "hole" opens up because from excitment. The more you excite them, the more wet they will get and the more their hole opens up. Also where their hole would be is where you will feel the wetness coming from. A girl has 3 holes down there---the pee hole, the ****** hole, and the *** hole. The vaginal hole would be right under the peehole but be careful because if you accidently slide into the pee hole it could hurt her a bit.
Once you find the hole, just slide in and she will know when you are in because she should feel pressure. You youself will feel your fingers enter into an opening. And then the same goes for you when she does it to you. Then from there enjoy.
Another kind of advice i have is: if you are both virgins, there would be a "curtain" where the ****** hole would be. You would break that when you finger each other. But let me say that if you both "pop the cherry" then there will be blood but it's not a bad thing, it's just your virginity.
Best techniques? hmm.. i'd say let her tell you what to do. I mean, unless you really want best techniques, just search on the internet there should be some.
If you have any other questions let me know.
I actually finished reading that even after I discovered it was a worthless reply...//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
wow!!
not only can i get great audio advice, i can finally take this new found info & maybe try & have *** .....with a girl!! //content.invisioncic.com/y282845/emoticons/graduate.gif.d982460be9f153bb54e5d4cb744f6ae8.gif
thank you for your detailed breakdown of the female areas...//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
d2k
d2k
uk
d2k
