help me finish my system
Bggd_GMC
Low & Loud
make sure that amp is full range first and yes lanzar max amps are decent for subs should be fine for comps on a budget other than that for sq I would go focal or mb quart just don't expect those cheaper lanzar amps to put out anything close to what they say
thanks...is this what you mean "FULL/HPF/LPF X-Over Switch" ?....
yes if it has a hpf than more likely its full range and have u looked at selenium comps and tweets cheap and sound good 2 they are 8 ohm though so if u decided to buy them I would recommend u get 4 speakers wire the right front and right rear in parallel to 1 channel and LF and LR the same way to the other channel will bring down to a 4 ohm load buy a couple of those super tweets ($20 shipped) and run them off your head unit they also can handle a lot more watts then those Candace
wish i had some extra cash to buy some tweets i already have all the speakers..... out of the 2 amps i listed witch one would you get?
if you search you can get those cadences for ~60 i got mine for 56 bucks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
as for the amp i have no idea.
---------- Post added at 07:50 PM ---------- Previous post was at 07:50 PM ----------
when it comes to comp amps I would spend a little more than I would on a sub amp u have to get a amp that has a flat frequency response and only adds color in a good way to your speakers go focal for sq they make some of the best studio monitors period I would figure Their car audio would be of no exception
yeah i got my 6.5 for $60 and my 5.25 for $46 cant wait to hear them
let me know how you like the cadences im installing them on the 25th as they are my... " Christmas gift " hahahahaha
Bggd_GMC
Low & Loud
Bggd_GMC
Fresno, CA
Bggd_GMC
