help me design a ported!
  • 2
nswartley
Down and out...
alright ive got 2 type s 10s, dvc 4 ohm getting 190 RMS each...i am making a ported for it. my maximum trunk space that i can use is 39 wide, 19 deep, and 14 high. i want it tuned for daily driving too. what size should it be? how big should the ports be (slot ports)? thanks a lot for your help. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i cant figure out how to use winisd god **** that program! //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
Originally posted by nswartley alright ive got 2 type s 10s, dvc 4 ohm getting 190 RMS each...i am making a ported for it. my maximum trunk space that i can use is 39 wide, 19 deep, and 14 high. i want it tuned for daily driving too. what size should it be? how big should the ports be (slot ports)? thanks a lot for your help. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Come on man...you are an expierenced user here...tell us what you want outa the box.
If you give me sub specs i can come up with something for u.
Originally posted by ridered36 Come on man...you are an expierenced user here...tell us what you want outa the box.
yea but when it comes to designing boxes i **** ass. i cant figure out how to use winisd either...i just want good daily driving with a little more SPL than SQ, maybe 60/40. my sub specs are as follows: DVC 4 ohm 10s, getting 190 watts RMS...what else do you need?
Originally posted by nswartley yea but when it comes to designing boxes i **** ass. i cant figure out how to use winisd either...i just want good daily driving with a little more SPL than SQ, maybe 60/40. my sub specs are as follows: DVC 4 ohm 10s, getting 190 watts RMS...what else do you need?
Try to make each sub get about 2.5 cubes. Try to use 38 wide, 18 deep, and 13 high, that will give you a little over 5.1 cubic feet of external dimension w/o driver and port displacement.
As for tuning, i would say around 35hz for a good daily driver. As for port dimensions, with the above dimensions for your box, each port would be 10" tall, 2" wide, and 12.91" long.
I dont know alot about Alpines and what they like, but this setup should at least get you in the range. If you get me the driver specs, i might be able to do even better:D
Originally posted by ridered36 Try to make each sub get about 2.5 cubes. Try to use 38 wide, 18 deep, and 13 high, that will give you a little over 5.1 cubic feet of external dimension w/o driver and port displacement.
by driver specs do you mean the QVC, and all that stuff? or what do you mean?
since its a lot to type...if you could just go here and there is an owners manual for them: http://www.alpine1.com/html/D2_n_1_n_n.html
go to products, then subs, then type-s subwoofers, then click sws-1041D, then scroll down and there is an adobe acrobat icon which has the owners manual and all the specs. on the 2nd page, my sub is the 4th one over on the chart...you will see what i mean. you can zoom in if you cant see it. thanks for your help.
read my previous post in case you already didnt ^^ :p //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
TTT in case you forget ridered //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif :) //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif :) //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
702
Buddy of mine somehow managed to get small MDF boxes set into the rear doors on his previous truck, think it was an F-150. I can't remember...
968
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
nswartley
Down and out...
nswartley
(Near) San Jose, CA
nswartley
    May 12, 2024
Brendon Jenness
    May 11, 2024
