box design 1.0 cuft
  • 5
avistar23
www.SoundhertZ.com <---
i am bulding a sealed box for my pioneer sub in my sig ::: would like it to be 1.0 cu ft
i will not be using MDF as it is to exspensive here any idears on how to make plywood perform better ?
thanks alot.
any help is apreciated
Mike.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
nah you see i live in the bahamas that was cheap for hear and MDF cost to much here so i have to use plywood. now wheres Jmac these days he disgned my first box where is he ?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I've been to Freeport it was just like Florida where I lived........anyway I know your situation use Marine plywood it has no voids &amp; is better than particle board &amp; more readily available in your area.Have you thought of fiberglass?. try to stay away from regular plywood because there are voids in the laminate which create leaks &amp; other nasty side affects.My second choice would be particle board if you can find it.
Nassau is much different than freeport .. much more islandy trust me..again all that stuff costs to much i have to use plywood. but i was thinkin of caoting the inside of the plywood with something to stop its bad charactiristiks.. some people say use something called pell and stick i think its some roofing felt stuff. oh well another day.
If you go with plywood, usually as stated in an above post exterior is better then interior. Marine plywood is even better yet. Look for plywood that has more layers to it as it will be denser and make a high quality box. When I was in school I work for a yacht company (Viking Yachts) and we had 3/4" ply that had a layer of lead in the middle, this was used on the floors to help deaden resonances caused by the engines and that stuff made awesome boxes!
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
193
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
504
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
604
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
avistar23
avistar23
Nassau Bahamas
choochooSS
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
