help me decide
millerscents
who knows what i am
first of next yr i am going to be ordering my new amp and was trying to decied between these 2 amps
planet audio bb350.1
Max Power (2 Ohms) 600x1
RMS Power (4 Ohms) 200x1
RMS Power (2 Ohms) 350x1
Signal-to-Noise Ratio 102db
Frequency Response 20hz-250hz
variable bass boost 0-12db
clasified by comp. as digital audiophile amp
or
planet audiovx400d
Signal-to-Noise Ratio 100db
phase inversion switch 0 or 180
variable bass boost0-18db
remote sub controler
the vx is able to be straped to a 2nd amp
and has a couple extras
eather one will be hooked to a
planet audio vsp128 12" dvc
VXP128
Power Handling (Peak) 650w
Power Handling (Continuous) 325w
Frequency Response 20hz-1.2khz
Efficiency (1 Watt/1 Meter) 92db
Impedance 4ohm x2
Voice Coil duel 21/2" aluminum
Magnet Structure 100 oz
Mounting Depth 7"
the amp will see aload of 2 ohm
give you ideas on these amp and these alone
thanks ben
millerscents
who knows what i am
millerscents
sapulpa, OK
Jordantyler
