Help me decide!
So which amp do you think suits me the best?
  • eD NINe.1
    Votes: 3 21.4%
  • Orion 1200D
    Votes: 4 28.6%
  • Kicker KX1200.1
    Votes: 4 28.6%
  • Phoenix Gold Tantrum 1200.1
    Votes: 1 7.1%
  • Other
    Votes: 2 14.3%
  • Total voters
    14
dustinr
Ok. Heres my dilemma.
I'm in the market for an amplifier that's class D technology, easy on my electrical system and reliable for daily driving. The amp must produce atleast 1000watts & be within my budget of $380.00.
My Car
My car is basically all stock, a stock 90A alternator; a stock Duramax battery (not sure on specs) My headunit voltage meter usually reads 13.9V-14.1V while my car is on. This is without any amps running. (just my cd player & coaxials)
I'm looking for something brand new that will match up well with a 12" Alpine Type R. The 12" is ported @ 36hz and will be in the trunk of my car. I have done my homework, pretty much scaped out all available amps.
So far, here is what I've came up with!
eD NINe.1
$315.00 Shipped with 3 year warranty. (forum discount)
http://edesignaudio.com/product.php?cid=4&pid=6&cur=USD
1200 x 1 @ 1 Ohm Mono
900 x 1 @ 2 Ohm Mono
450 x 1 @ 4 Ohm Mono
Signal to Noise Ratio -95dBA
Variable Input Sensitivity 150 mVolt - 7.0V
Remote Variable Input Sensitivity Yes
Variable Low Pass X-Over 40-240 @12dB
Current & Thermal Protection Yes
Remote Bass Equalization Yes
Variable Phase Control Yes
Master / Slave Option Yes
Efficiency 64%
Variable SubSonic Filter 24dB/Octave, 15Hz - 50Hz
Fuse(s) 4x30
Max Current Draw 130 Amps
Orion 1200D
$339+$30 shipping
http://cgi.ebay.com/ORION-1200D-Monoblock-Amplifier-Class-D-Car-Sub-Amp-NEW_W0QQitemZ5817211891QQcategoryZ18797QQrdZ1QQcmdZViewItem
Class-D Monoblock Amplifier
RMS Power Output:
425 watts x 1 chan. @ 4 Ohms
725 watts x 1 chan. @ 2 Ohms
1200 watts x 1 chan. @ 1 Ohm
Intelli Q bass optimization circuit and remote gain option
Separately adjustable, selectable variable high-pass filter with proprietary Copy/Master control circuit for RCA outputs
Selectable 12/24 dB/octave variable low-pass filter
Copy/Master feature supports gain and crossover adjustment matching in multiple amp
Allows external bridging of two matched gain amplifiers
Switchable phase invert function
Heavy gauge direct-wire high current satin finish power and speaker terminals
1-Year SonicElectronix Warranty
Kicker KX1200.1
$335+$37 shipping
http://cgi.ebay.com/BRAND-NEW-Model-KICKER-KX1200-1-MONO-CL-D-1200WATTS_W0QQitemZ5818807935QQcategoryZ18797QQrdZ1QQcmdZViewItem
Number of Channels 1 - Mono
RMS Power (4 ohms) 300 watts
RMS Power (2 ohms) 600 watts
RMS Power (1 ohm) 1200 watts
Bridged RMS Power Not Bridgeable
Peak Power Output 2400 watts approx. (1 ohm)
Min. Impedance Unbridged 1 ohm
Min. Impedance Bridged N/A
THD @ Rated RMS Power N/A
Speaker Level Inputs Yes
Amp Preamp Outputs Yes - 1 Pair
Built-in Crossover LP (50 - 200Hz)
Bass Boost 0 - 18 dB
Signal-to-Noise Ratio 95 dB
Fan Cooled Yes
Fuse Rating 150A
$255.00+Shipping(6 hours left on auction, with no buy it now)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5816907578&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
Amplifier Type: Mono
RMS Power: 1200W x 1 @ 4 Ohms
THD at 4-Ohm RMS Power: n/a
RMS Power: 1400W x 1 @ 2 Ohms
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >95 dB
Fuse Rating: 80 amps
High Efficiency (over 70%) Class T Circuitry
Thermally Efficient Heatsink
Timed Acoustically Integrated Muting (TAIM)
Differential RCA Level Inputs
Preamp Outputs
18dB / Octave Low-Pass Crossover
30Hz to 300Hz Continuously Variable Crossover Frequency
18dB / Octave Subsonic Filter
Variable Twin-"T" Bass EQ Circuit Provides Up to 18 dB of Boost at 45 Hz
Optional RMD Remote Monitoring Display Port
Optional LPL Low Pass Level Controller Allows for Driver's Seat Adjustment of Bass Volume
2-Ohm Stable
I've put alot of thought into what I'm going to be buying the past few days and still can't make up my mind! I've done my homework & these were the amps that kinda spoke out to me. I am still open to any suggestions/ideas and hopefully someone can give me their experience with these amps & suggest what I shall do. I'd just like to add one last thought. I'm the type of person who likes extra security. I don't want to buy someone elses problems or anything. I like warranty or knowing my amp isn't goint to be D.O.A. I work hard for my money, so please keep your suggestions reasonable. Thanks!
Thanks in advanced.
Dustin
u forgot one, my jbl 1200.1:) , but if not its between the tantrum and the kicker in my book
Yes, I already know that those amps are probally the best amps I have listed, but they lack warranty which is VERY important to me. I hear alot of good & bad things about the eD NINe.1. Most of the bad things are from Caraudio.com & SSA forums. I'm not a eD lover.. never owned anything by them, I just know theres alot of eD haters out there because of their owner.
and Niggz, can I get some info on your amp? I didn't know you had one for sale //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
P.s. I also had considered buying an US AMP from Flakko. The Merlin MD1. It sounded like he really went out of the way to get me the price that he got. I'll just say it's in my budget. (I don't think he wants me to say a price)
Any thoughts on a US AMPS Merlin MD1?
bah eD 9. watever amps are good. dont listen to them hataz out there.
Hey Flakko!
I am also considering the Merlin MD1 still, as you might of read. Have you had any experience with the NINe.1? I see you have a NINe.2, how do you like that?
Hey Flakko!
hola mi amigo, //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
only my 9.2... does its job, and only got a lil warm after playin for like 2-3 hours on and off with 3-4 minute breaks (delivery job) in 90 degree weather. As for the 9.1, never experienced it but you know where i stand lol
Well, the 9.2 and 9.1 are totally different amps aswell. Have you got your hands on one of those manuals for the MD1 yet? //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
tomorrow my friend... tomorrow, ill get some pix too //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
WEWT! I'm awaiting until I see them then, kk? Hehe. Can you also take some pics of some us amps stickers/decals? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yea sure that wont be a problem but you know wat, ive never seen them (the decals/stickers) myself...
bleh.. that tantrum is getting high! So I doubt I'll go that route. I kinda started looking into the Diamond Audio D6 1000.1 anyone know anything about them? I'd also be REALLY intrested in a Memphis Audio MCD1000 but can't find one anywhere in my budget //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
p.s. bump for the night.. im off to bed
Any suggestions guys?
Also, tplaya said he could get me a DLS CAD-11 for $375 shipped with warranty. What do you all think about that. I really haven't heard too much about DLS.
Thanks,
Dustin
dustinr
dustinr
Moberly, Missouri
dustinr
