Help me choose
i emailed the 2nd link, " Here is an older Alpine deck that has barely been used, and is in pristine condition. This is from back when Alpine made the ultimate SQ/tuner decks. You can see I responded in the forum and actually wanted to pick it up:p Great signal/noise ration, 3 sets of strong pre-outs, CD player, digital time alignment, AUX input but no usb. This is an absolute beast and you can't go wrong with this one, especially at the price! Oh, and the seller is a good guy too, I've talked to him a few times: Car Audio Classifieds "
Does this sound like a good deal ? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif hopefully will get it,.... i need the amazon link to mount it alo correct
---------- Post added at 04:44 PM ---------- Previous post was at 04:43 PM ----------
i like the 2nd and 4th link, emailed the guy with the 2nd link //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
FUCKKKKKKKKKKKK@18924982735109837510932857................
They are out of Obsidian 15" 4ohm's till February apparently .... 2nd option?
the last 1 u postd, u said its $140?
( Alpine CDA-9886 CD receiver at Crutchfield.com )
i like it:D but the link i don't think is the same ( for the used )
Look under the pics, he lists another headunit that he doesn't have pics of yet!
And yea, you still need both the items I linked from Amazon.
Options instead of the Obsidian... If you're trying to stay in the same quality/price bracket, I'd go with the b-stock SA-15 from: Used, B-Stock, Refurbished Amps, and MISC - SSA Car Audio Forum
And since they're only available in D4, you'd have to get the MB Quart 1500.
or this for a bit more: SSA Store - SKAR Audio VVX Sub woofer
Or: https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154e0baada639b0/shopdata/0050_Speakers/0040_SSD/product_overview.shopscript
^ Luv dem Fi's!
mmmm the SSD15 looks ****... its d2, soshould i get the quart 1500 or 1000?? hmm.
is it worth it? ive heard they are good //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
---------- Post added at 09:53 PM ---------- Previous post was at 09:53 PM ----------
also a few of the head units ( both.. ) of the ones i have looked at don't have the front aux in, so can i likeee errmmm.. wire it through somehow so i can use it while driving?
think ill get the Fi 15" ( SSD )
2ohms
should i get anything else, the cooling , flatwind coil, internal lead, etc.
Getting dustcap either blue or yellow //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
also.. in need or amp still ! if i get the 2ohm FI, should i get a 1200 watt amp or so ? or the quart 1500 or 1000
Size of sub/s or quantity do not determine whether or not you will need another/bigger battery, but the amp/s that is/are powering the sub/s does/will.
a quart 1000, will it require one?
and also, do you reccomend the quart 1000? i would like to get a 1200 watt amp to run it at 1ohms since its a d2 sub , But it may require a battery //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif need info ordering soon! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
JBL GTO14001-Z 1500-Watt Mono Subwoofer Amplifier (500369311514) | eBay
win and bid on this jbl 14001, then run your amp at 4 ohm. at 4 ohm this bad boy puts out 1200rms. it also makes the distortion level go to THD 0.05% (rated power at 4 ohms) and amps are most efficient at 4 ohm usually in the 80 to 90 percent range on class d. so your alternator will be much happier and no electrical will need to be done. where as if u run at 1 ohm efficiency usually goes down to 70 percent and its going to want more power.
I have a old school fosgate 1500 sitting in front of me
at 1 ohm its 63 percent effecient
at 4 ohm its 86 percent
nope u can run 1 ohm or 4 ohm on a dual 2 ohm sub. 2ohm coils wired in parallel equal 1 ohm. 2 ohm coils wired in series give you 4 ohm. 4 ohm will be nicer on your system and its a much better amp then mb quart. its direct from jbl and they always sell for around 175 with 8 bucks shipping. its an amazing amp really
Tek18
Tek18
KY
fullwoofer2121
