natisfynest
Balls Deep In Your Mom
ok just need some subs for the time being low ball under 100 for both so which ones would you get
first is the Hifonics HFi12D4
RMS Power Range : 300 Watts
Peak Power Handling: 600 Watts
Impedance: Dual 4 Ohm
Diameter: 12 Inch
12-Inch DVC and SVC Subwoofer
High-Energy Magnet
For Ported or Sealed Enclosures
Black Polypropylene Cone
Poly-Mica Cone Damping
Chrome Speaker Frame
Multi-Layer High-Temp VC
Front-Plate & Voice-Coil Cooling
Integrated Spider Tinsel-Lead Design
Hi-Excursion Rubber Surround
High-Strength Suspension Material
Push & Insert Wire Terminals
Anti-Resonant Rubber Magnet Boot
next is the Memphis 15-PR12D4
12" Dual 4 Ohms Power Reference Series Subwoofer
Power Handling:
Peak: 500 watts
RMS: 250 watts
Impedance: Dual 4 ohms
Polypropylene cone woofer
High-strength wide roll foam surround
Powder coated grey vented basket design
Tough rubber top gasket
Dual 4 ohm voice coil
50oz. Magnet structure
Sensitivity: 88 dB
the hifonics are bout 70 for both shipped the memphis bout 90 for both shipped or do you guys recomend some other subs for the same price a pair shipped that would be better
Diameter: 12 Inch
High-Energy Magnet
Power Handling:
Peak: 500 watts
RMS: 250 watts
Sensitivity: 88 dB
