Help me amp gods!
Clarity
Hi all, new to the forum. Looking at getting a relatively cheap but clear sounding setup going. Diamonds in the rough so to speak (nothing comp worthy, just something clear hitting that can be cranked when needed). I'm new to setting up car audio, but I've been reading up on it for the last week or so. It's helped a great deal finding these forums (searches and stickies).
Car: 2004 Dodge SRT-4 with stock Livin' Loud Kicker System (sounds pretty good minus the crappy woofer)
Here's what I've got so far:
Head: JVC KD-HDR1
Sirius Tuner: JVC SIR1
Subwoofer: One Boss Blade BL220 DVC 12" Sub (600W RMS) - jumped the gun and got this because of a really good deal. Since reading in here that Boss maybe a name to avoid, I hope I didn't make a mistake, but the specs seem ok.
At this point I need help on a Sub amp. Like I said I want to go cheap, but not at the cost of quality. I've been looking at either the MA Audio HK1000D($186) or the Hifonics Brutus BXi1606D ($250). In comparison both seem good.
MA Audio HK1000D:
1000 watt RMS Digital Class-X Mobo-Block Amplifier
Temperature, Voltage & Output Level LCD Display
RCA Outputs: 1 Pair
Thermal, Short & Overload Protection Circuitry
Platinum Plated Screw Type RCA Jacks
Double Sided Black Epoxy PCB Board
Strappable with another HK-1000D
Platinum Plated Block Terminals
Fully Unregulated Power Supply
Stainless Steel Finish Heat sink
Quiet Fan Cooling System
Remote Gain Control
Full Mosfet Circuitry
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control at 45Hz
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
1 Ohm Mono Stable
Hifonics Brutus BXi1606D:
1600W x 1 RMS @ 1 ohm
Illuminated Heat-Sink Design w/Blue LED Light Pumps
Ultra-Fi MOSFETS
Fully Adjustable Accu-Cross Crossovers
180 degree Variable Phase Control (15-35Hz)
Variable 24dB Subsonic Filter
18dB Variable Bass EQ @ 45HZ
Pulse Wave Modulated MOSFET EXVP
Twin-Turbo Torroid Coil Design
Surface Mount Design
Balance Line Inputs
RCA Line Output for Amplifier Daisy Chaining
2 Ga. Oversized Gold Power Connectors
Dash-mountable bass remote included
From just a pen and paper aspect from what little I know so far, these seem fine minus the fact that the MA Audio shows Class X. I've never heard of a Class X amp, is that just a buzz word? I've also seen it referenced as Class T, and once site even claimed it was Class D, so I'm clueless as to what it actually is. Plus I read on here that the MA Amps were excessively power hungry.
The Brutus looks to be a solid class D, and while it doesn't have a fan, my guess is that it doesn't need it. Are these pretty power hungry as well?
Any other recommendation on amps between $150-250 (brand new preferred)? Essentially, I'm wanting to run my sub at 600W RMS, maybe 800W at the most.
Thanks in advance!
you can search ebay, there are some kicker kx600 amps there for arround 150 shipped. http://cgi.ebay.com/KICKER-KX600-1-MONO-AMPLIFIER-600-W-SIM-ZX750-1-DEAL_W0QQitemZ180078864926QQihZ008QQcategoryZ79829QQssPageNameZWDVWQQrdZ1QQcmdZViewItem This one has ended, but its a good example. Birth sheet shows 704 watts, at 2 ohm.
good luck
x2. why would you get a 1400 watt amp for a 600w sub???//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
Awesome, thanks!
I'll keep an eye out for the old model Kicker's. Would you say that the previous one's I listed are probably not that good then?
DFW represent! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Awesome, thanks!
no theyre OK amps its just that they will destroy that sub...boss isnt really known for underrating their subs
Gotcha, so pushing past RMS spec on that sub is not something to fool with on it. What amp would do you think would be best for pairing?
pairing what two of those subs? and orion 1200d prob or sometin like that
boss subs ****..since ur already @ half way of *******...go for the full ******* and get a boss amp to...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I would steer clear of the MA audio, the Hifonics you can use just make sure the gains are trimmed down properly and the sub will be fine, however since you are on a budget you can spend less and still be fine. That kicker amp is a great amp and meets your requirements. I would check flee bay a little bit more for one of those or comparable. Also anything alpine, MTX, most phoenix Gold, rockford or orion are all good choices as well.
link to the boss sub? that 600w rating might be max power, which RMS might only be 150-200, so finding an amp to power it will be that much easier/cheaper. like stated above, dont over power it, and you'll be fine
Clarity
Clarity
Dallas, TX
Clarity
BP1Fanatic
BP1Fanatic
