Help making box design with sketchup
sketchup is one easy application to learn, take your time with it. make each piece or baffle at a time to its corresponding dimensions and youll end up with a box then you can cut circles and ports holes on the baffles them self. try it for a while youll get the hang of it.
I just downloaded the program last night, and sketchedup some boxes, but I can only save it to .skp file format. Is there a way where I can save them as .jpg or such?
fun program btw.
you need to make the front baffel to the desired thickness example 3/4"
then draw a circle. then use the push pull tool and push the circle back 3/4"
CJL
CJL
oZone
bean-a-reano
