help load my box
  • 4
How much clearance does your box have? My buddy has a downfire box built for his TJ and has 2 type r's in it. Sounds pretty nice BUT when up high the subs hit the floor on some notes. So now we have to add another inch on the bottom. How much power you lookin to run? More SPL or SQ? I was just gonna recommend SE's but see trigger already has. Maybe run a mono amp to each one? Do you mind buying off ebay and what not? Or is your $1000 strictly retail? Are you keeping your electrical system stock?
stock electrical system, i believe there is 2 inches of clearance, i would say spl with the top off, but sq, i want it to be loud and sound good. id buy off of ebay if the price was better... i dont want cheap equipment. what is an RE SE?thanks guys! - Ed
what dual 6 ohm subs do you guys suggest in my price range? i think i have found options in JLw3, MA100D6, audiobahn: ALUM10N. I like the RE SE's arent dual 6 ohm. what companies am i missing? is there any other options than dual 6ohm?
Lil help? anybody have success with a tri 10 sub amp combo with the same airspace i have to work with ? 2.0 total, .66 per chamber. thanks
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
Just remembered, I have that same coaxial/comp set, BNIB, $245 shipped if you are interested. I have the matching coaxials, took these of the...
12
274
Using Sky High copper OFC wiring and Stinger 8000 series rcas. The US Acoustics usx4085 is rated at 85X4 @ 12.9 volts and proably close to 100w X...
6
231
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
668
lephatrabbit454
lephatrabbit454
ny
lephatrabbit454
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
