Dude I was never in wood shop class and all that, never ever messed with wood until I built my first box. It just seems kinda scary //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. Have someone design a box. There are many guides online to help assist you in it. BTW this winter it was too cold to build a box outside so I had a shop here do it. I show up to find a blown XXX. //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif . Sounds likes the guys in your area aren't much better //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. Btw I saw your post on the multi meter. Did you measure the amps output on the speaker terminals(proper gain setting), as well as check the rca voltage to make sure its sending a proper signal?No, im not against getting a box (even though i have no idea how to build a box nor the carpentry skills, nor do i wanna drop hundreds on getting one built) but i honestly don't know if even then this sub will have the SPL i am looking for.
excursion has nothing to do with box size. The sub will move regardless. Change your box, its cheaper than gettting a new sub.
You have good equipment and lots of potential, you just need to get past whatever is creating this problem.
try to find something that would work or see if you can get a box made for TA/cameros. Hell even see if you can find a pre fab that would fit.
Sealed boxes are easy to make, get the dimensions of your trunk and someone can easily design a box.
i think u have shitty install, and even shittier settings on your amp. no pun intended but rip it outand start over. i have the same **** setup in a trunk car and at times, cant stand to listen to it. it moves air quite nicely..in fact moves my hair a tad. mine is a 15 in 1.4 cubes....ur 12 wont be quite as loud but it is a **** GOOD sub. redo ur full install and see what happens....check your box for leaks..i swear i gaind 5 db just siliconing my box.
Dont roll eyes, you will start annoying people, then they wont care.
Why? Easy, different people have different tastes in music. Just becaue you dont like it dosnt mean the next person wont.
But what you are looking for is not going to be obtained with your current box. I thought you had 1cuft net, I was wrong. You need around 1.25net which will put the box around ~1.45ish gross. Do this and get the wiring fixed and get your HU and amp set properly and you should be good to go.
Lots of people use this woofer with outstanding results, something is wrong with the install, not the woofer.
