mattsv8_03
hey guys ive done some research on this amp. its in my 97 yukon. it has two outputs wich ive come to understand is a parallel output. i have two kicker single voice coil 10s 4 ohms. wired pos neg to one pos neg to other. is that 2 ohm. if not how do i wire them for 2 ohm or 1ohm. the amp dosent hit very hard at all. unless its wayyy up and the gain is all the way up. also if i switch to dvc comps should i go with 2 ohm or 4 ohm and how would i wire them for 2 ohm or 1 ohm wiring. i know its a lot of questions but i figured u guys could help. the wiring diagrams i found at crutchfield and the like only show the wiring with one output. not two.
