help i think i fried my amp
  • 4
brooksi
ok i have a legacy LA490 600 watt amp pushin 2 JBL GT Series 10's. I am using 8ga wire. My problem is whenever i turn it on the green power doesnt come on any more now the red protection light comes on can somebody please tell me what that means?? i am just wondering if i need to get a new amp or a way to fix the one i have
nope he means that you have to connect your subs differently...it could be that you have them connected in parallel...try connecting them individually to each speaker output terminal...ie...connect your left sub to the left output...and the right sub to the right output
how many channels does your amp have ?
if thats still not working...check your ground connection...it may have become loose
good luck
its a 2 channel amp, i noticed that when i touched the end of the ground wire to the amp it didnt do anything and i know normally when u have the battery connected it should spark so maybe my ground is loose
i tried just putting it back into its channel, do you think i should rip up the carpet and check it? i was thinking of running 4ga wire anyway so if it doesnt work with my 8ga then i am going to rewire it with 4ga maybe it will work then
well before ripping up your carpet...you can use a circuit tester to check that your are actually gettin current in your cables...if you are gettin current then go ahead and rewire...if you are not gettin current...then i believe there MAY be something wrong with your amp
good luck
You might want a new amp!!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
187
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
555
392
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
367
brooksi
brooksi
chippewa falls, wi
RangerMan
    May 18, 2024
    May 16, 2024
