I'm helping a friend hook up a basic 4-channel amp to power all his door speakers. My problem is that his door speakers are STOCK component sets (we're not doing aftermarket right now). Both speakers have a 4ohm load (Pictures 1 & 2). I've pulled his door apart and even his carpet and am completely lost on how to wire this to a 4-channel amp. I was expecting to find a passive crossover of some sort in there somewhere and have no luck. Instead, his tweeter & mid both have Green/Light Green wires (Picture 3). They run separate and appear to join together before they make it out of the Door grommet and into the car itself (Picture 4).
In the 1st picture there appears to be a capacitor on the tweeter. If so, I would assume this is what takes the place of the passive crossover. Even still, how does this load affect the wiring? It seems that if they are ran in series or parallel instead of through a crossover, the produced impedance would be 8 or 2 ohms load produced at the source.
I called a local shop and spoke with the installer. he said that the tweeter has no impedence, and thus the load seen at the headunit is 4ohms (due to the speaker only). This makes no sense whatsoever to me.
Can someone explain this to me? The amp we have can do 40 x 4 @ 4ohms, or 50 x 4 @ 2ohms so if these are in parallel that's fine. Still, how in the world is this wired? I'm lost.
Pictures:
Tweeter w/Capacitor
Door speaker
Wires joined to 1 set
Wires (in foam) coming together in door
Pictures:
Tweeter w/Capacitor
Door speaker
