Help highs amp keeps blowing fuses
IMOVeCHICKENS!
Firtyfwe here ngz
I have an American Bass SQ475 the fuses are 2x20 i have the gains set so at 4 ohms bridged i get 200x2 well it keeps blowing fuses and ive replaced the fuses several times today i dont know whats up i set my gains using a DMM and the fuses just keep going should i use larger fuses?like 25amp ones?
you short by like my grounds ? sorry i dont know it was loud as hell with the AAchaos 15 on a saz1500d in my trunk but this amp will just blow fuses on pure will
alright cool its a really short amount of wire so i should be able to find it, if thats it
also if thats not it should i just put in 25 amp fuses instead on just replacing my 20s all day?
Do not upgrade your stock amp fuses! They are already designed/sized to be 20% over the amps max power so you should not be blowing them.
Check the power/ground connections to make sure they aren't arcing.
If you are replacing the fuses constantly it won't be long before you fry the amp.
well i checked all the wire there are no shorts >
not sure what it is, im going to set my gains again and maybe that will fix my problem if not im dropping fault on my amplifier but i opened it once it first started blowing fuses and there was no visible damage anywhere.
any other suggestions on what my problem might be?
IMOVeCHICKENS!
Firtyfwe here ngz
IMOVeCHICKENS!
727 FLA
IMOVeCHICKENS!
