HELP! hertz comps jl 10w6v3 distributionblock zx750.1
b0wl_of_weed
canada
Hey guys! Names Brandon. Anyways I got a 20
10 crew cab dodge I got a couple questions as for I love music but can build a house but dunno how to hook this stuff up so I pay someone but I don't like being scammed so here it goes.
I got 4 6.5 hi energy hertz speakers and a hdp5 channel amp. So I got factory head unit not the screen but the SLT dial version. And a PAC thing for rca wheel controls then 4 gauge running to the back behind seat with hdp5 amp running the speakers in doors.
Then I just bought 10" fox box driver side ported. And I'm buying a jl 10w6v3 and I'm ganna throw it in the foxbox.
And finally I got a kicker zx750.1 mono amp I wanna use to power that jl. Now here's where my ISSUE IS I need a distribution block? Anything else I'm ganna need? Do I have to put a deck in my buddy had a used pioneer deck that would probably work that's double din but suggestions please?? Before visions makes me buy a bunch of **** I don't need.
Also how hard is this process to do by myself haha distribution block got my confused. And if I paid for a installer what would be a good price for this install seeing as speakers and wire already done just need sub and distrbution block.
Also what bub think born my set up for crew cab dodge
Thanks guys!!
you can wire the distribution block if you've done everything else.
1. disconnect battery
2. disconnect power wire from amp
3. connect power wire into distribution block input
4. connect wire from dist. block output 1 to amp 1
5. connect wire from dist. block output 2 to amp 2.
amps can ground separately.
this, without the capacitor
That is strange there. Thats what Ive encountered with low voltage before . That Kenwood needed a Firmware update and that fixed that one when it...
17
Yes, one shop is absolute best and last time they let me return it even when i mounted it on the car and tried it :)
thanks dude thats by far the best feed back ive got, as for the key mem, i belive thats for a ACC to turn it on.
960
432
b0wl_of_weed
b0wl_of_weed
canada
CSCStang
