I'd go with fused to be on the safe side.ok.. and do i need to get a power block thats fused or will a regular one work?
Should be fineok thanks man... i got an 8 gauge kit already will that work for a two channel amp?
this kit is only availible with 250a fuse is this ok?I'd go with fused to be on the safe side.
You will need:
0/1 ga kit. Check Knukonceptz.com (http://www.knukonceptz.com/productDetail.cfm?prodID=KLM-AK0)
1 ANL fuse block w/ 300a ANL fuse
2 distro blocks (one fused w/ another 300a fuse)
4 ga wiring to run from the distros
Ring terminals, zip ties, etc.
