Alpine MRD-M1000 Amp and Pioneer AVIC-N4 Problems
Okay here goes. I have an Alpine MRD-M1000 Amp and A Pioneer AVIC-N4 head unit. I have everything wired right, as well as I know. Power Wire Hooked to battery with In-Line fuse. Solid Ground... I ususally always run my remote wire to my Radio Fuse. and the RCA plugs are running to the Sub-Woofer output on my head unit. When you turn on the car and the radio comes on, Amp reads between 12.0 and 14.0 volts, but with no amps. I tried figuring it out on the head unit cause i know in some theres a way to turn that pre-out off but I couldnt figure it out... I tried the other outputs on the head unit, but with no luck. Any Ideas would be greatly appreciated.
Thanks
A. Menges
Correction: Decided to move the remote wire to the power amp wire in the wiring harness of the head unit... no difference
dababyboy3123
dababyboy3123
Bolivar, OH
dababyboy3123
