You should be fine with a 500 watt amp on your factory electrical, use as big of power and ground as you can though if your amp will accept 2 gauge then use that. Also I use to really advocate the use of a capacitor, but now I believe they are just a waste this may cause alot of debate but i have seen tests done where a cap has very little to no effect. Besides just looking cool specially the ones with the voltmeter built in, they are not worth the money.Thanks, that was exactly the info I was looking for. Also with that size amp will I need to get a HO alternator or should I be able to get away with just a capacitor?
