Help! Factory amp issues
LoudCrownVic
1/1 of Team Team Team
I am trying to wire the factory amp from a '94 Dodge Caravan to a JVC Headunit. THe Front speakers only work the way in which I wired it. I believe I did not tap into the correct wire in which for the amp to "turn on".
Does anyone know the location of the factory amp so I can check which wires I need to connect to? Or, which is the correct wire that needs to be tapped into with the remote turn on? It really sucks having bad sound!!!
Thanks in advance!
LoudCrownVic
LoudCrownVic
Scales Bump, IL
LoudCrownVic
