Help does this sound right?
greg2100
I'm trying to make my sealed box into a ported box. I've been searching around for a while and I keep getting the same numbers. I'm trying to figure out how big the port has to be. The box is for 2 12" L7's and it's 34"x30"x14.5". I was going to just make a slot port but I was using the box for 3 L7s and one of them blew. So now I have a hole where the blown sub was and I want to put a port there. So basically what I'm saying is every program I've used said that the port should be 6" wide by 6" high by 6.80" long. I don't think this sounds right so I wanted your opinions. Thanks.
I wanted to tune it to 35 Hz. and I was going to make a semi removable port so that I wouldnt have to seal up the sub hole and then cut another hole in the box. Does that sound like a good idea? or should I just add another baffle on top of the original one and cut new holes for the subs and port?
it would be easier and more cost-efficient to simply remove the entire baffle, trace the size of it, and cut a new one. from there, you could determine your port and sub placement and tune your port accordingly.
greg2100
greg2100
Tampa,Fl
dannyz122001
michigan born
    May 14, 2026
michigan born
    May 14, 2026
