help design a build, I have parts/need advice
greeneye
Hey there I've got a bunch of parts and want to go for a SQ install.
I'm shooting for a 2-sub 4-mid 2-tweeter all active setup and I'm looking for any advice I can get.
How would you configure the system, and what more would you buy or trade for?
So far I have:
promos25 (2ch x25W-4ohm, 2x50-2, 2x100-1, or 1x200-2 etc, no xover)
promos450 (4x50-4, 4x100-2, 4x200-1, 2x400-2 etc, no xover)
pc2600.2 (2x150-4, 2x300-2, 1x600-4, hi pass xover, sub xover)
pc4800.2 (4x100-4, 4x200-2, 2x400-4, hi pass xover, sub xover)
deq230
pqm210
2 jl audio 10W6V2 subs (600W rms each, dual 4ohm voice coils each)
q-bass control knob
MP3 head unit I can use for now, but it's a f-ing jensen for the love of GOD.
wires, cables, fuses etc.
I still need:
a crossover or two
sound deadener
4 mids and 2 tweets
I'm looking to spend less than $1000 more bucks.
Oh ya, I don't have the car picked out yet but I'm due to trade in so I'll probably get a 4-door SUV.
So... here's an idea to start it off.
run all active 3-way setup
promos450 bridged into the 2 subs, pumping 400W into each.
4800 running 4 mids at 4 ohms 100w each
2600 running a pair of nice tweets up front at 150w each
rest of the stuff stays on the bench.
Am I going to regret having tweets only up front?
I could sell an amp and get a 1200 W art series for the subs, worth it?
Looking forward to the ideas, THANKS!
Update,
I'm looking into buying a 21400 for the subs and selling the 450 or using it elsewhere.
I should be able to eliminate the need for an external xover this way.
I can use the 2600 for tweeters, then use the low-pass output from the 2600 along with the 4800 running in high pass mode to create a band-pass for the mids. Then I run the subs off the 21400 in low pass. Next thing I need is tweets, mids, a pack of deadener, and sub boxes.
Also I'm wondering what size unported box to use on those 10w6v2's. Manufacturer recommends .625 which I'm sure is fine but I would be interested to know if anyone here has a preferred volume.
...wondering if anyone is out there. any ideas?
I'm leaning towards buying a 21400 and running the subs in 0.69 cu ft sealed boxes.
Not sure about going all active though.
If I go with passive x overs with the 4800 then I can sell the 2600 and buy a better set of components.
I got a 21400. Running myself into serious debt here but oh well.
Planning to set up each sub as 8 ohm, then wire in parallel, and bridge the amp into the 4 ohm pair.
Lots of ways to wire them but this way each one gets it's own independent supply with identical signal.
Now I need components. Listened to the Focal 165v30 and liked them. But that was the only pair in that class at the store.
I'm thinking about getting 4 focal polyglass woofers (165V2/6v2), one for each door, then running tweeters up front only.
Thanks in advance for any thoughts. Don't be shy let'em fly.
greeneye
greeneye
minnesota
greeneye
