lyons238
So I currently have a 2013 Subaru WRX with some work done to it. What I have...
- 2x 12" Fi Q's (but my friend wants to buy one)
- dcpower 250a alt
- 1x Sundown SCV-2000
- 1x D3400 batt
- 1x XP2500 batt
This is all perfect to run 1x Q. If I run two I would need...
- XP2500 second battery
- Sundown SCV-2000 amp strapped
Also in order to fit the two subs the box specs would be 4 net cubes, 32hz, but only 9.9 sqin port area per cuft or around 37sqin port area. So the port area is not ideal, is this far to small? My designer thinks it will be fine but I'm not so sure.
If I ran a single Q I could get perfect box specs without any sacrifices besides the output of having a second woofer. Being that it's a Subaru and not a competition vehicle, do you all think I would be better off running the single or dual Q's? Running two subs would put close to 300lbs in my trunk, take up the entire thing, cost more money, and leave me with no spare tire or room in the trunk. If I run a single Q it will only be about 160lbs so 150lbs lighter. I'm coming from a single AQ HDC3 15" in a ported box off 1500w in a single cab truck and I was more than happy with the output. Will the single Q likely satisfy me or should I stick with the original plan and run two?
- dcpower 250a alt
- 1x D3400 batt
- 1x XP2500 batt
