HELP!!!!! D300 + pac, i might be screwed
Hockyeyd214
Krew Kustoms
I installed my d300 and everything worked fine but I just received my Pac Tr7(for video bypass) and I was installing it. Like a retard I did not unhook my battery and when I was wiring the pac up, the 12volt wire touched the brain of my d300 and sparked. I grabbed it off quick and then was like S#!+. I checked the fuse box behind the d300 and it is good and also check thed fuse box next to the brain, it was all good. I hooked it up after and now my unit wont even turn on!!! Should I check my fuse box under my hood or did I fry the brain? Help PLEASE!!! //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
i checked the fuse box that is right behind the d300 with my buss fuse tester and it seemed to be fine. Should i maybe replace it anyway?
better to replace as many fuses as u can and maybe just maybe u wont have to spend all that money again.... my suggestoin is replace every fuse possible ( that would have anything to do with ure unit) spend the 10 bucks on fuses to troubleshoot....
Hockyeyd214
Krew Kustoms
Hockyeyd214
San Ho
joetama
