Help cooling my amps in my installation.
  • 4
pimpingiraffe
21
Michigan
I have a 95 Chevy S10 Extended Cab truck. I'll be putting an e12a that i have in the rec. ported box in the rear, and i'm going to be raising the floor in the back about 3 inches. I plan on mounting my amplifiers (JBL bp 600.1 for sub and 80.2 for components in front) under this floor. One side may have a plexi window to show off an amp, but I doubt I will do that at this point.
My issue with that setup, with them under this false floor is cooling. How am I going to keep these amps cool so they dont overheat etc? I've been told fans, but what kind of fans, and how do I set them up to be powered?
I'm hoping this false floor will turn out good, so I can hide things better, and they would be less likely to be stolen. If I do the plexi, that would look rather nice also. But the main issue here is cooling, what should I do, if I need to do anything at all.
Any ideas/Suggestions or Problems with my idea? Please let me know asap I want this to be set up as best as possible.
-ET
Use some fans like this.. they move a lot more air then reg. pc fans..
Some Found Here.. http://www.sounddomain.com/sku/STISF3
I would place a couple on either side of the amp.. and have it circulate through the floor ( 3" Constructed one ) & up into the cabin area.. kind of like this.. ..Ps.. Sorry for the 2nd grade art.. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Red = Sub Box
Green = Amp
Blue = Floor
Purple = Fans
Brown = Air Flow
Please, could you tell me where I could get some fans such as these, and how much they would set me back? Also anything special I need to know about wiring them?
-ET
I would place a couple on either side of the amp.. and have it circulate through the floor ( 3" Constructed one ) & Up into cabin.. kind of like this.. ..Ps.. Sorry for the 2nd grade art.. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Red = Sub Box
Green = Amp
Blue = Floor
Purple = Fans
Brown = Air Flow
SORRY For The Double Post.. //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
I forgot Computers were the same current as cars. I have about 10 92mm high cfm fans that i can put in there. Do I just run a wire with a fuse from my battery back to the fans, and then ground the fans on the chassis, or run a ground back to the battery? Thanks So much
-ET
jus run a small power wire to a relay that is triggered by the remote wire to the amp.....and ground it to the chassis or make a common ground for them...
Could you possibley draw a small diagram of what that will consist of, and where can I get one of these parts? Radio Shack? What exactly do I call itw hen I ask for one.
-ET
Originally posted by pimpingiraffe I forgot Computers were the same current as cars. I have about 10 92mm high cfm fans that i can put in there. Do I just run a wire with a fuse from my battery back to the fans, and then ground the fans on the chassis, or run a ground back to the battery? Thanks So much
-ET
Make sure it's a brushless fan. (it should say in the middle of the fan, motor area) //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You don't want to use high cfm fans, if it has high air turbulent noise. Don't use delta fans.. try Zalman with the resistor module attached. You dont' need a whole lot of air moving, so long as it's circulating well..//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
181
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
545
391
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
366
pimpingiraffe
pimpingiraffe
Michigan
paikiah
    May 16, 2024
    May 16, 2024
